progress database
michaelslott
Forum Visitor
Forum Visitor
progress database
Post by michaelslott »
how to connect to progress database what is the correct syntax
trice001
Forum Visitor
Forum Visitor
Re: progress database
Post by trice001 »
As pointed out as of now there are a wide range of programming houses who make database programming, for example, Microsoft, Oracle and IBM to name the huge players in the market. SQL Server, Oracle Database and DB2 are the names of their product, individually. The greater part of the diverse programming stages as of now specified make them thing in like manner and that is the model whereupon they are altogether based; that being the social model. This model has been around since the 70s and embraced by a great deal of the now huge players in the market. Every product house has actualized the model in a marginally extraordinary manner however they are in a general sense the same. Since they are altogether comparable it would be workable for somebody with a foundation in, say, Oracle to figure out how to utilize Microsoft's SQL Server before long. The range of abilities is unquestionably transferable. A dialect called Structured Query Language (SQL) is utilized to control and cooperate with the database. Diverse makers have marginally unique goes up against this dialect yet are comparable. For instance, Oracle utilize something many refer to as SQL and SQL Server they call it T-SQL. They accomplish a similar result however for the most part with different syntax.
a.facility_code = ifnull(nullif(?,''), a.facility_code)
Thanks& Regards,
Angel anave
Web Design Company Toronto
bogomazovroman
Forum Visitor
Forum Visitor
Post by bogomazovroman »
From the Windows Start menu, select Administrative Tools > Data Sources (ODBC) OR select Run, enter "odbcad32" without the double quotes and click OK. In the ODBC Data Source Administrator, select the System DSN tab. Select the OpenEdge ODBC driver appropriate for the OpenEdge version of the database to be connected. Drift Boss
Maeve785
Forum Visitor
Forum Visitor
Post by Maeve785 »
To access the ODBC Data Source Administrator, navigate through the Windows Start menu by selecting Administrative Tools, then Data Sources (ODBC). Alternatively, you can open it by typing "odbcad32" into the Run dialog and pressing OK instagram story download. Once inside the ODBC Data Source Administrator, switch to the System DSN tab. From there, choose the suitable OpenEdge ODBC driver corresponding to the version of the OpenEdge database you wish to connect to.
Angel17
Post by Angel17 »
Such an awesome post. Keep us updated!
water heater colorado springs
