Google Sheets as Data Source
PeeWhy
Post by PeeWhy »
Is it possible for Noventri to use a google sheet as the data source?
Re: Google Sheets as Data Source
Hi PeeWhy,
Google sheets are natively in a currently unsupported format (extension .gsheet) for Noventri Suite. However, there is an option on Google sheets to export/download your file as an Excel spreadsheet. After doing this, data could be pulled into Noventri Suite from the Excel file.
Hi PeeWhy,
Something else you might be able to use for managing an Excel sheet is Microsoft Excel Online in harmony with Microsoft One Drive. This will allow you to sync an Excel sheet online with a One Drive folder on your PC. Then in Suite, you can connect to the One Drive version of the Excel sheet.
Microsoft Excel Online has multiple user capabilities as well, so numerous users can have access to the shared Excel file. Please go to the links below for more information about these two Microsoft services.
Microsoft Excel Online - https://office.live.com/start/Excel.aspx
One Drive - https://onedrive.live.com/about/en-us/
