Weather not updating on one server instance
Posted: Wed Feb 11, 2015 2:36 pm
by rdflesher
We have 4 server instances running on our server PC. For some reason, one instance (with a single SF-200) stopped updating the weather on Dec 10th. Everything else updates on this player as designed but not the weather. Other players on other servers are working just fine so I know the data feed is ok. I've rebooted the played, updated the project, re-downloaded, even took the slide out of the sequence for a week and re-inserted it. Same result - Dec 10th? Thoughts?
Re: Weather not updating on one server instance
Posted: Mon Feb 16, 2015 10:19 pm
by Martin-Noventri
Hi rdflesher,
To clarify, what version of Noventri Suite are you using? Can you publish one of the already working projects with weather to the server instance in question and schedule it to the single SF-200? What about creating a new project containing just a weather slide?
Posted: Tue Feb 17, 2015 2:07 pm
by rdflesher
Based on your suggestion of taking a page from a working project and copying it to this one, I ultimately discovered that the non-working project had the server name hard-coded in to the page and database properties. We upgraded the server last month and I guess we didn't realize it was hard-coded in the weather page, when it was installed. Working just fine now after I changed the properties. thanks.
