The default shortcut is to NDS_Splash.exe
Lately this has failed on every startup..
Faulting application name: NDS_Splash.exe, version: 2.12.68.2641, time stamp: 0x53ecf55f
Faulting module name: NDS_Splash.exe, version: 2.12.68.2641, time stamp: 0x53ecf55f
Exception code: 0xc0000005
Fault offset: 0x000015e1
Faulting process id: 0x1ab8
Faulting application start time: 0x01cfe6d902e414f5
Faulting application path: C:\Program Files (x86)\Noventri-player\bin\NDS_Splash.exe
Faulting module path: C:\Program Files (x86)\Noventri-player\bin\NDS_Splash.exe
But I find running NDS_Suite instead, Noventri starts up OK.
Is NDS_Splash important?
NDS_Splash Fails
Re: NDS_Splash Fails
Hi amason,
Thanks for the post. You can bypass the NDS_Splash.exe if needed. It briefly launches a splash screen with the Suite version number while Suite loads.
Can you provide us with more details? What OS are you experiencing this on? What version of Suite did you upgrade from?
Now that you have successfully opened Suite with NDS_Suite.exe, can you confirm if NDS_Splash.exe is still broken?
Thanks for reaching out to us!
