Weather Slides
clabedz
Weather Slides
Post by clabedz »
Greetings,
It was brought to my attention that our 36-hour weather slide does not appear correctly. When I look at the slide provided to us, it has some data overlapping with high/low temperatures. When it displays on the screen, it shows both (one yellow and one blue) and it is hard to read.
Shouldn't this only display one temperature at a time depending on time of day?
Thank you.
Re: Weather Slides
Hello clabedz,
Our weather provider has made some changes to the data we receive. This now allows us to get both the High and Low temps at the same time. Previously, we would only get the High's during the day and the Low's at night and so we designed our weather to fit this. With the new changes, the 36-hour page will need to be adjusted by moving the high/low text region so that they are side-by-side.
Once the regions are moved, simply republish the project to update the changes (no need to reschedule). The 36-hour weather slide will now display both temperatures on the 36-hour weather page.
If you need any assistance with these changes, please let me know. I will be glad to help any way I can.
clabedz
Re: Weather Slides
Post by clabedz »
Thanks, Sergey.
I will post the changes today.
Re: Weather Slides
Hello clabedz,
Sounds great, let me know if you have any questions or need my assistance.
