Setting up Dynamic Pages
Working with Text Files, Image Lists and more.
Re: Setting up Dynamic Pages
I want to setup dynamic pages that cycle through 5 departments and shift assignments for temp workers for the data for each department. Sounds like dynamic pages might be the ideal solution.
Should I see it cycle through all the pages in sequence preview in suite?
Any plans to add cycling through columns too. For example cycle through all row in col 1 then col 2 then col 3. Instead of having to create 3 pages?
mark
To see a preview of all the dynamic pages, simply select the dynamic page you want to preview inside of the "Edit Sequence" sub-tab, and then press the right and left arrow keys on your keyboard. It will cycle through all the available information in your database so that you can preview it.
About cycling through columns - could you illustrate a scenario in which you would want to do this, so that we can get a better idea of how it would work?
Thanks trent
I have a list of departments (columns) and assigned works. I'd like it to show dept 1 workers (pages 1-n), dept 2 workers (pages 1-n) ... dept n workers 1-n
I could do it with current implentation of there was a way to say start new page if dept changes and data contained only two columns: dept and worker. e.g.
Dept Worker
1 Tom
1 Dick
1 Harry
2 Sally
In this instance, I would get n-pages for dept 1 and then a new page (+ n pages) for dept 2
Currently my data is like this
1 2
Tom Sally
Dick
Sally
So I have to have 1 dynamic page for each dept and sequence them all
It works, but with 10 departments it a lot duplicate effort when creating/editing pages
Mark
