Digital Signage Forum - Noventri • Importing Powerpoint
Posted: Tue Feb 18, 2014 5:38 pm
by clabedz
Greetings. Every time I load a powerpoint with more than one slide, I have to go rename the slide from the directory to Slide2.png. The Noventri Suite calls them slide1.png and slide2.png, but the directory names them slide0.png and slide1.png. Therefore, one is always blank. Is this perhaps a bug?
Re: Importing Powerpoint
Posted: Tue Feb 18, 2014 6:02 pm
by David L
Hi clabedz,
I am a little confused as to what is happening. If you could please call us at 301-790-0103, we can have a tech support engineer go through the steps with you to see if we can recreate it.
David
Posted: Tue Feb 18, 2014 6:16 pm
by clabedz
Thanks. I called and explained that and another problem I am having with updating powerpoint. It may be related to Office 2010. Hopefully they can test it out and see if it is something that can be fixed easily!
Posted: Wed Feb 19, 2014 2:16 pm
by Ralph M
Hi clabedz,
Thank you for your patience while we investigated this issue. This is something we haven't encountered before and will account for it in the next release of Noventri Suite. It seems that the default setting in Microsoft PowerPoint may have been changed. This setting was causing the numbering format to begin at "0" and not “1”. Following the steps below, this should resolve your issue.
Using Microsoft PowerPoint, open up the presentation. Click on the "Design" tab and then "Page Setup". Change the "Number slides from" value from "0" to "1" and click on "OK". Now your slides will begin at “1” and not “0”. Save your presentation and import the presentation into Noventri Suite.
I hope this will help to resolve your issue. Thanks.
Posted: Wed Feb 19, 2014 3:23 pm
by clabedz
That's great news. Thanks for all the info and I look forward to downloading the next version, though I'll be able to work around my powerpoint issues until then.
Thanks again!
Posted: Thu Feb 20, 2014 9:53 am
by Ralph M
You are very welcome. For any future matters, please let us know. Thanks.
