USB Serial cable?
Linas
USB Serial cable?
Post by Linas »
I am using a usb to serial cable from tripplight and it seems to not work
will not shut down my NEC monitor?
is there some configuration a need to do to get the USB to work?
Re: USB Serial cable?
Hello Linas,
There are many brands of usb to serial cables that may or may not work. Most usb to serial cable should work but we have only tested a few. Depending on the type of cable you have, you may need to use a null modem cable. This makes the straight cable into a cross-over cable for data communication. Once the usb is connected to the SF-200 and the null modem connected to the monitor, you should be able to send commands.
If you have any other questions, let me know.
