How does powerpoint work?
Posted: Wed Aug 29, 2012 9:25 am
by GeoffStein
I saw this in the feature list when I upgraded but I dont see a button for it
Re: How does powerpoint work?
Posted: Wed Aug 29, 2012 9:32 am
by Trent S
Hello GeoffStein,
You can find the new PowerPoint Import feature in the File Menu by clicking "Import PowerPoint."
We've put together a tutorial video that will walk you though the process of bringing PowerPoint presentations into Noventri Suite, which you can find at this post:
Noventri Suite PowerPoint Import Feature Tutorial
Please let me know if you have any questions, and I'd be happy to help!
Posted: Tue Apr 16, 2013 10:26 am
by Eltechadmin
Hi there
Just download the free version, to test if this could be the solutions for us.
Basically, my situations is that we have a reception, with a big screen, hooked with a PC.
We want to display 2 different powerpoint slides on this, where on of them, is more or less update daily,
with information of visitors for the day.
So my problem is, after importing the powerpoint slide, into a new project, the contence is not shown, in preview.
It only show a little thumnail called "image 1".
So any idea what the problem is ?
Posted: Tue Apr 16, 2013 12:02 pm
by Viktor S
Hello Eltechadmin,
When you select the Edit Page tab in the Design portion of the software and select your page do you see your PowerPoint slide content? If you do not see any image then the PowerPoint project was not imported properly.
Try importing the PowerPoint project again and make sure to follow the steps in the following video:
http://www.noventri.com/forum/viewtopic.php?f=6&t=441
Also, could you please provide the steps that you are taking in order to see the preview?
If you have any other questions please feel free to ask.
Posted: Fri Apr 19, 2013 1:48 am
by Eltechadmin
Hi
I have seen that video and follow the instructions (fairly simple):
1: Select import powerponit from file menu.
2: Name project and select a powerponit file.
3: Select "add powerpoint to sequence" and give the sequence a name. (I've also tried with selecting this).
4: Selecting resolution and then pres OK.
And as mention I can't see the contense of the powerpoint file, witch by the way is made PowerPoint 2010 and is very simply, 1 slide only with text (just for test purpose).
Posted: Fri Jul 26, 2013 5:24 pm
by Viktor S
If this is a reoccurring issue please contact us using our direct support line. 301-790-0103
Thank you,
Viktor
