CSV Files & Data
Using Excel,SQL,Oracle, and other ODBC Compliant Databases
clabedz
Trusted Contributor
Trusted Contributor
CSV Files & Data
Post by clabedz »
Greetings,
I am having trouble with a few different things related to CSV files. I may end up writing this in a web page to avoid some of the complications, but wanted to see if these things are possible.
First, I have a file that has headers. Unfortunately, Noventri only sees the first three headers and the rest are null. Is there a reason this would not come through? I am trying to change all the fields headers to not have spaces, but the first few fields have spaces in the header name, but they come through fine.
Second, I am trying to see if I can add fields together. While currently modifying the CSV file to include totals, I would like to know if I can add fields togehter, either through a custom SQL statement or through Noventri. The addition does not appear to work within Noventri, and I have not been able to get it to work on the SQL statement. Has this been done before?
Third, I saw the posts on displaying characters in either red or green, but is it possible to have a whole box in that color - dependent on the data? It does not appear that there is a way to put one text object in front of another based on database input.
Any help would be greatly appreciated!
Thank you,
Carol
Martin-Noventri
Re: CSV Files & Data
Post by Martin-Noventri »
Hi Carol,
Great questions! We have clients who are doing similar things as you are trying to accomplish. It would be good if we can look over your database to see the best way to implement this, as each workflow is different from client to client. We will have one of our support specialists reach out to you to get a better understanding of your specific needs.
