Hello Billy,
Thanks for downloading and using our software.
You can use the Noventri Suite software as stand-alone digital signage software without the use of the SF-100e appliance, but there are some limitations. One of them is remote publishing, which can only work with the SF-100e appliance.
To use your laptop as a digital signage player with our Noventri Suite software, you will have to edit the content on the laptop/player and hit the play button in the Edit Sequence section in the Design tab.
Alternatively, you could edit your content from your desktop and publish the project, then use your laptop/player to load that project from the server and follow the same steps above.
To get features such as transitions between pages, database capabilities, scheduling, remote management and many others, consider using the SF-100e as your player solution.
What are the benefits?
Solid-State Design - No moving parts means virtually no maintenance.
98% Energy Savings - Less than 4 Watts of electricity is consumed making the yearly cost of operation much less than a
PC.
Sleek, small form factor for easy mounting behind the screen
Field Updatability - No more running around to each player in the field to load new software
These are just a few of the benefits that you would receive by using our SF-100e appliance. If you have any more questions, feel free to contact us at any time.
Andrew Hoffman
Vice President
800-359-1858
andrewh@noventri.comSkype ID: Spec-Comm
http://www.noventri.comhttp://www.noventri.com/forumhttp://blog.noventri.com/
