It is currently Fri May 24, 2013 9:10 pm
 Post subject: Overview
PostPosted: Thu Aug 18, 2011 3:12 pm
Overview
1.1
Noventri Suite™ makes it easy to create projects to be displayed on monitors in
resolutions up to 1920x1200.
1.2
To display the projects you create on your monitors, you will need a player for each
monitor. You can use your computer as a player however the Suite™ is designed
specifically for use with the new Eco-Series™ line of Noventri players.
1.3
Each project that is created in the Suite™ can contain any number of pages (limited
only by the resources of the computer being used).
1.4
Each page created in the Suite™ is capable of containing multiple image, text, and
clock regions.
1.5
Each region supports transparency and can overlap other regions to create interesting
effects.
1.6
Timeline interface enables you to create a sequence of pages with transitions. A
project can contain any number of sequences (limited only by the resources of the
1.7
An easy-to-use scheduler allows sequences to be played any time, day or night, or
as needed.
Note: This feature can only be used with the Noventri Eco-Series™ line of players.
1.8
Playback your sequences on either your main computer monitor or a secondary
monitor. Any number of Eco-Series™ players can also be added.
Go forward to the next section!
Return to the Table of Contents
