Monitor12.1 - Auto Adjust12.1.1 Most monitors have an Auto Adjust button or setting that will automatically adjust the screen to fit the displayed image.
12.1.2 If a monitor is not displaying your Project correctly, it most likely needs to be adjusted. Consult your monitor’s User Manual for instructions.
12.1.3 In some cases, the monitor’s Auto Adjust will not line up an image properly. This is possibly due to an image that is too dark or contains too much black area around the outside. For best results, use Auto Adjust with a picture that has some kind of a border around the outside of the image for reference.
12.1.4 Once the monitor is adjusted to an image at a specific resolution, all subsequent images at that same resolution will also be lined up.
Note: Noventri can provide you with a Project created for your specific resolution. It contains several images at each resolution specifically designed to be recognized by monitors.
Go forward to the next section to learn about the Scheduling Tab!Go back to the previous sectionReturn to the Table of Contents
