It is currently Tue May 21, 2013 7:20 pm
 Page 1 of 1 [ 9 posts ]
 Post subject: Noventri Suite 2.8 Released!
PostPosted: Tue Dec 06, 2011 10:39 am
*NEW* Version 2.8.7 of Noventri Suite has been released!
This newest version of 2.8 has several bugfixes and a few exciting new features!
Noventri Suite Version 2.8
Major new features include:
- Support for the new SF-200
- Adjustable Preview Interval
- Optimized Communications
- Optimized ODBC connections (connection pooling)
- Fixed PPT import bugs
- Select all in the designer panel
- Added default group options
- Created distributed version updated to suite clients
- Users can change their own password without an administrator
- Scheduler panel fixes
- Many general optimizations to increase performance significantly
Noventri Suite Version 2.6
- HTML Capture
- Image Cropping
- XML / RSS Data Source
- New Powerpoint Import Options
- Scheduled SF-100e Reboot Option
- Check Box to Maintain Schedule Duration
Recent fixes/enhancements since the last 2.4 version:
- Faster SF-100e boot up
- Added warning message for low database update intervals
- Added warning message for low page durations
- Faster player updates and downloads
- The interface no longer flashes / updates when regions are nudged
- General bug fixes
Known Issues:
- Issues when changing multiple user permissions
Noventri Suite Version 2.4
- PowerPoint Import (available through the file menu)
- Ability to close projects
- Splash screen to let you know the software is loading
- Ability to put the monitor to sleep when an SF-100e is stopped via manually pressing the stop button in the manage tab
- Multi-select cut, copy, and paste
- Region Search(Find)
- Letter spacing (Tracking)
- Image List and Drop Folder
- Fixed bug that would truncate database data beyond 127 characters (limit is now 1023 characters)
- Bug fixes for disconnected player
- Permissions multi-change of groups and users
- Sorting problems in location panel
- Bug fixes for crashing on sequence deletion
- Download or delete multiple projects from server
- Added validation to sequence names
- Warning added in installer to let you know that firmware will update on your SF-100e players immediately after install
- Tons of bug fixes
Get the new version!
Tim Rollins
Executive Director of Operations
 Post subject: Re: New Version of Noventri Suite Released!
PostPosted: Thu Dec 08, 2011 5:22 pm
What are the system requirements for the server?
What you you mean by "Dynamic Pages"?
Why would you want multiple servers running?
Trent S wrote:
Version 2.2 of Noventri Suite has been released!
- Much faster content downloads via SSL encryption and compression disabling (these features are disabled by default)
- New layer stacking functions added (bring to front / send to back)
- Undo / Redo ability added
- RS232 Control
- Updated/New resolutions that should work on a wider range of monitors
- New resolutions should allow VESA sleep to work on a wider range of monitors
- Dynamic Pages
- Playback can now start while still updating (faster initial time to screen)
- Noventri Server now runs as a service
- Ability to start multiple servers on the same computer
- Tons of bug fixes
PostPosted: Fri Dec 09, 2011 1:46 pm
Hello rdflesher,
Below are the following minimum system requirements for Noventri Server:
Windows Operating System (XP SP3 - Server 2008 Recommended)
Pentium 4 Processor
10/100BaseT Ethernet port (if using networked players)
512 MB Ram
C++ Redistributable 2007
138 MB available on disk for program files
Additional space on disk for content storage
Dynamic Pages automatically create pages based on the amount of information in a database. Instead of putting several pages in a sequence that all tie to the same database, you can now put one dynamic page in the sequence and it will "repeat" itself until all of the information in the database is exhausted.
A good example is our Flight Board Package - we use dynamic pages to create pages based on the number of departures at the nearby airport. We are currently working on documentation for this new feature and will be posting it on the forum once it is complete.
Regarding multiple servers - this was included mainly for the sake of organization. Our clients wanted to organize their digital signs by individual location. Running multiple servers allows for individual locations to connect to a server that will only show them the particular screens and digital signage players that concern them (while still keeping everything central on a Server to be monitored by a corporate entity or otherwise).
Let me know if you have any further questions.
PostPosted: Thu Jan 19, 2012 3:59 pm
A couple of questions.
Do you have any more documentation on the server installation and the different configuration screens and options available. The information on the forum basically is a click on the .msi and confirm the settings. I'm having my network guy install it on one of our Windows servers and he will need a little more info (and so do I). After installed is it only configurable from the server console?
Secondly - any progress on the documentation on dynamic content ? I'm also in the Dynamic Pages documentation.
Thanks
PostPosted: Fri Jan 20, 2012 3:20 pm
Noventri Support Specialist
The Noventri Server Manager controls the server(s) and service running on the pc. If selected, it is installed as part of the installation. The new installation allows you to start the servers along with the physical machine as a "Service". There is also no limit to the number of instances of the “Noventri Server” that one may use. Each instance can be uniquely configured by Name and Port that it will use, remembering that no two servers may share the same port number.
If you have never logged on the the Noventri Manager Utility, you will be presented with an initial “Logon” screen, requiring a Service Manager / password pair. The default Service Manager is already running on the current machine, and is given the name “localhost”. If you are attempting to log onto a remote Service Manager you will need to put in a valid IP/HOSTNAME or URL to the machine to which you wish to logon. The default logon information is as follows:
NOTE: If you have ever changed the logon password or default port, you will need to enter the new information instead of the defaults
Service Manager: “localhost”,
Password: “ noventri”,
Port “20939”
Once logged on, you will be presented with the Noventri Manager Dialog. Refer to the following photo of the NDS_Manager program in action.
In the above picture, the “Gear” icon on the desktop will launch the Noventri Server Manager. Notice that the default server is already created for you, with the default port number of 20940. If an additional server is desired, then simply click the “Add Server” button, and the new server will appear automatically. Notice now that the port number has automatically been incremented to the next numerical value.
In the above photo, we can also see that the check box is automatically set to start the new server instance. This will ensure that this server will automatically restart if any system reboot, or crash occurs. The end result is that the customers content is safe even if there is a problem on the physical machine.
To change any of the values listed in the dialog presented, all you have to do is click once on the item to change, and then start typing the new data. If there is a specific port and name for this customers’ server, then this is the place to configure it.
As shown in the following photo, If you desire to change any of the Service Manager log-on information, you may do so in the Advanced tab of this program. If anyone wishes to change the location of the Root Log and Work directories, then the browse button of the appropriate item can be used to make the necessary changes.
Now, in the next photo, we would like to address the issue of Log and Work directories. The Root Work Directory has all of the new server instances “Sub-Work Directories” within it. If you notice by the photo, the Default server work and log directories point to a “Separate” sub-folder than that of the other Server_2 instance. This effectively keeps only the specific server content that corresponds to itself in that particular sub-folder. Any Clients that are logged on to a server will never see or have access to another customer’s material. To explore the differences I encourage you to highlight the server that you wish to query, and use the “Browse Files” / “Browse Logs” buttons to examine the information contained in each folder.
Because the “Noventri Manager” is a server configuration utility, there is really no need to modify or set Windows Registry settings. If you have done so, I would recommend that the “Noventri Software” be uninstalled, and any modifications should be reversed in the registry before proceeding. Once that is completed, please reinstall the software to reset the registry to known state.
We understand the security risk that are involved with allowing port forwarding within your network, but if a good Hardware Firewall is chosen, as perhaps part of the router solution, we are convinced that there is very little danger of intrusion. What we recommend to avoid having to keep adding new server ports to forward, is to simply reserve and “pre-forward” a range of available ports to the server physical machine. This will help to create new servers with the foreknowledge that the port number will be one digit more than the instance above it.
Only the Noventri Server currently being modified is affected by changes. It is necessary to restart just that process in order to re-initialize and accept new data changes. The Service Manage does not restart, and neither do other running servers.
The Dynamic Page documentation is almost complete and will be posted soon. I will follow up in this post as soon as it is ready.
If something above is not quite clear or you have any other questions, please feel free to post them below.
Sergey Kravchenko
Office: (301)790-0103
Fax: (301)790-0173
PostPosted: Sun Jan 29, 2012 12:31 am
How many Screens can we switch on each SF-100E. I need a solution for 4 screens.
PostPosted: Mon Jan 30, 2012 3:23 pm
Hello xavkick
The SF-100e was designed with the idea of one player to one monitor functionality. If you could provide some more information on what kind of monitors you plan on using ( Brand and model number). It would be very helpful. Do you want to display the same information on 4 screens or do you want to be able to control them with commands?
If you have any questions feel free to ask. We can help you come up with a solution.
Viktor Seredich
PostPosted: Mon Jan 30, 2012 11:31 pm
Viktor S wrote:
Hello xavkick
Thank you for your answer. We are using 4 LG Professional M4213CCBA . .
Sorry for the quality of my English.
We need 4 screens because we have a very large list of products to sell. On every screen we publish a different part of our menuboard.
If I understand it, must therefore Install Noventri Suite on a PC and have a module "SF-100E" behind each screen ?
Or can we establish the menuboard and install a single "module" SF-100E "that will drive the 4 screens and cut menuboard according to my needs on each screen?
Thank you for your answer because I am very interested your equipment. (We have several restaurants) and plan to install your solution in one first to test this solution.
Xavier
PostPosted: Wed Feb 01, 2012 10:29 am
Hi Xavier,
Thanks for clarifying that for us. To run a different portion of your menu on each screen, you will need four (4) SF-100e players and four (4) DVI-HDMI cables for your model monitors.
You will create a project with the portion of the menu you want to display for each player. The player can be scheduled to turn the monitors on and off and change the menu items.
One PC running the Noventri Server can manage all of your players in all of your restaurants as long as there is a network/internet connection available.
We can also do an on-line demonstration for you and answer any questions pertaining to your installation and workflow in detail. Just click this link. http://www.noventri.com/digital-signage-demo.php
Viktor Seredich
